What model should I be buying ?
Peerlessk
Lima NY
Is there a guide for the best unication option/model pertaining to your zip code address ? would like to gift a pager but wanna buy the right one . Thanks
Whiskey3JMC
LMR Explorer
Philly burbs 🇺🇸
Assuming you'll want to monitor Livingston County, I believe the minimum you'll need is a Unication G2. However I'm not sure how it performs on simulcast. G4 only offers 700/800 so a VHF G5 might be your best option
N6ML
Although I haven't tried it, I would expect that the G2 should handle simulcast in the same way that a G5 would. The firmware-based demodulator should be the same - it's just a different RF front-end for each band.
Peerlessk
Lima NY
14418 , yates county NEW YORK . not much simulcast in that area. however when i take my g5 out that way it covers my area monroe county/livingston . thanks for the replies
Listen365
After a long spell of being out of the radio hobby, I am relearning. I live in the Roanoke Virginia area and cannot find anyone who sells pagers.
I am quite unknowing about which pager would work in my area, so can anyone assist in what direction I need to go.
Thank you for your help.
N6ML
You might be better off starting in your local area forum, to determine what systems are of interest for you to monitor, then try to find a radio to meet your requirements. e.g. you might decide that you want to be able to monitor both RVRS and STARS, in which case a VHF G5 might be a good option (although the VHF receiver is not stellar, since it uses an internal loop antenna).
