What now???
jdb585
Scott County
So I got all of my LE, Fire and Sate Agencies all going well. Got the basic understanding of programming etc. What else should I start listening in on? Military/Aircraft would be an interest, but I dont know and Freq or what I could hear in south Scott County. Any ideas?
wogggieee
Hugo , MN
You probably wont hear much military in scott county. And as far as aircraft go you'll only likely be able to hear the planes and not ATC.
mmtstc
Ø
Minneapolis Area
the Federal protective Service 407.000 NAC $201 repeater is very strong... you probably could get it out there. You also might have luck with some of the TSA frequencies. Civil Air Patrol is around...
162.0500-166.4875 MHz - repeater inputs
166.5000-169.5000 MHz - simplex
169.5125-173.9875 MHz - repeater outputs
406.1125-410.9875 MHz - repeater outputs
411.0000-415.1000 MHz - simplex
415.1125-419.9875 MHz - repeater inputs
Federal Agencies (MN) - The RadioReference Wiki
Military Agencies (MN) - The RadioReference Wiki
Common Frequencies - The RadioReference Wiki
Federal Protective Service - The RadioReference Wiki
Transportation Security Administration - The RadioReference Wiki
Simplified Channel List - The RadioReference Wiki
