what order ?
KE5BCP
Analog Man
Lewisville, Texas
Why does the order matter?
From the manual, page 73 (pdf):
"Control Channel Only Mode
When this function is activated, trunking is performed using
control channel data only. Voice channel (also known as
“DATA channel”) frequencies do not have to be programmed
into memory. This feature only applies to Motorola 800 MHz
systems."
JoeyC
Senior Member
San Diego, CA
If however you DO choose to enter all those freqs in and NOT use control channel mode only, you DO NOT have to put those freqs in any order. Only EDACS and LTR systems must have freqs in a particular order.
