What radio is this?
NLACo
Los Angeles County
Hello, I am trying to find the model name or at least the manufacturer of this radio. It is used by Riverside County Sheriff.
natedawg1604
Colorado
It's a BCT8 scanner, with BearTracker(tm) Warning System with 800MHz TrunkTracker III.
Almost every patrol car I've seen has a scanner in it to monitor other agencies, etc.
Wow. This was obviously installed a longggg time ago. Very interesting.
wa8pyr
Technischer Guru
Staff member
Lead Database Admin
Ohio
Looks like a Harris M7100
Could be an Orion, too. I've interchanged control heads between them before.
Only way to tell for sure is either read the radio, or look at the model/serial tag on the radio body.
merlin
DN32su
I have one of those on the bench right now.
From the display, that has to be an M7100. That is vintage also, Riverside went to Motorola, early 90s
ElroyJetson
Orion M725 or M7100. Good radios, but the M7300 is a better platform, newer, and pretty easy to find at a good price. If you're interested in the M7100, the M7300 is what you should look for.
Most importantly, seek out one that has the features you need.
rescue161
KE4FHH
Hubert, NC
Also, if you need 700 MHz or Phase 2, stay away from the M7100 and do as Elroy says and go for the M7300.
wa8pyr
Technischer Guru
Staff member
Lead Database Admin
Ohio
The M7100 has worked out great for us as our site is 800 MHz only, but I would add to that.... avoid the M7100 if you need Link Layer Authentication. Since Harris is not going to add LLA to them, this means I have several agencies who will have to replace the bulk of their mobile fleets over the next three years. Mucho dinero.
On the other side of the coin, I'll be able to do away with RPM and consolidate all my codeplugs into RPM2, which will simplify my life to a certain extent.
wa8pyr
Technischer Guru
Staff member
Lead Database Admin
Ohio
I wish we could do that, but we have way too many 100P portables.
We have one... my personally-owned one. I love it for my own use, but the thought of a whole fleet of them? Not so much.
What we have a whole boatload of XL200P, and I'm OK with that.
