What was your first CB radio?
N1AGH
Bulverde, TX
My first CB was Sonar FS-23. A big unit which I used at home and in a 1964 VW bug. I had to put a 12 volt battery under the back seat since that year VW was still 6 volts.
PACNWDude
Chrome metal cased Courier 23. Older tube type radio. Still have it and has aged very well. Most of the past 20 years it has been in storage though.
KC3ECJ
Midland 13-882C, a 23 channel mobile.
I also have a 40 channel Uniden handheld with the waether band.
No SSB radios though, but I would like to get one.
n2hbx
Lady Lake, FL
Mine was a Robyn WV-23A. Used to irritate my ex-father-in-law that my little stock Robyn and Antenna Specialists trunk lip mount antenna would consistently out-talk his "peaked-and-tweaked" RCA set with dual antennas on his "big truck."
Also had a Midland base radio at the same time, but can't recall the model.
Larry
KB0VWG
My First
It was a DAK Mark 3 I think 40 channel mobile, then a cobra 148Gtl and the base was a Uniden Madison base which I just sold last month, i had that base for 30 Years.
kb0vwg
wqoi992
I guess i kinda show my age I am 46 now and got the base when I was 16. lol
Garymaxon1234
Pacer II with Plus2 mobile mic, mosley devant special ground plane, later and an Astro beam a trick stick for horizontal ops.
vsp5151
Globe CB 100
Mine was a Globe CB100 3 channel crystal controlled. Tube type and it worked on 6 or 12 volts or 120VAC. I think the vibrator was replaced with a solid state type device to make it more modern. Probably bought the replacement device from Olsen Electronics in Ohio.
Blind_Shadow
My first was a Johnson II for base or moble. Used it on base for a while, then put into car when I got one. Was one, if not the best CB I ever owned.
Tulsa
An Allied Radio single channel transmit with a tunable superregen receiver, I built from a mail order kit. I added a 5 channel crystal deck and a front panel switch I wasn't old enough to drive but I built quite an array of test equipment from kits. My mode of transport in the early 60's was my Cushman Super Eagle, l ordered a CB portable and when I was riding my Cushman I would stay in touch with my mother, not a bad life for a fourteen year old.
pjtnascar
Sussex County, NJ
Mine was a hand-me-down Cobra 19 Ultra. The first rig I ever bought was a Radio Shack TRC-444. Once I really got into CB I had a bunch of rigs like the Uniden Washington and Gtant XL and the Cherokee CBS 1000. Sold most of it for big $$$ to finance my Ham station.
impalass427
Connecicut
I also started with a Globe CB100 3 channel, then a realistic TRC-X23 (Courier 23) which I still have and use once in a while. have a collection of at least 20 tube- type CBs, even a Eico 762, the one on the Andy Griffith show. I worked at radio Shack 1968-69. Don
Orbieswar
Australia
A Pearce-Simpson fan at the time
My first CB was the P/S BOBCAT 23D.. I fell inlove with woodgrain and brushed aluminium look on the front panel... still do !!!...I still cave a couple of their radios, but sadly I don't have Bobcat any more.
Dawn
Pinecrest,Fl
First was a Pierce Simpson tube Companion II that was retired from my dad's business after he got set up with business band. I think it was six channel, but also had a tunable receiver. I went to work for RS shortly afterwards and first bought 2 mini six channel TRC-11's that were on sale, followed by a TRC-30 Navaho base. One of those TRC-11's wound up in my first vehicle and the other I traded to a guy for a Pentax Spotmatic SLR that was worth easily 5x the then sales price of the CB. I swapped that camera for a Ruger 22 bicentenial marked pistol that I still have. Worked out to a good legacy deal worth more then everything combined. Still have the TRC-30 in a box somewhere. Made some lifelong friends that almost all became amateurs except one that I still keep in touch with.
tripplenickel
monroe, georgia USA
It's really hard trying to remember anything over 50 yrs ago, but it was a Heathkit which I believe it had three (3) channels (crystals) which unplugged from the front panel giving you the option to change to different channels if you wanted too. A lot has changed from then to now, I think all the old records were lost in a fire some years ago including liscense records. I cannot find any record of my original KCF 2144.
555
George1955
Spacemen
Hey, I found you again. They closed the other forum.
Finally figured out that first rig I had we were discussing about a year ago.
It was a tecraft falcon mark V
An he15
Then I got the regency imperial.
Hope you're well. Let's catch up
George
TheSpaceMann
An he15
George
How have you been? The HE-15 was one of the original CB classics!!
George1955
Fair... I still haven't got the antenna I bought up. I think I'm just going to hire someone
To put it up. Even with that in mind, can't find anyone but... I will. When I do .. Let's see
If I can reach you ... Might need a little "help" which I have ... So hopefully In a week
Or 2... I have a friend coming to help mount the antenna. I got one on those 4 PC,
"Big stick" type.
I was hoping to go to that ham rest , I think you told me about it on the other forum
Again, that forum shut down so....
Anyway.... Keep me I the loop if you hear of another..
I got some info on the imperial rigs to get them in shape. I do wind up trying to buy
Some more... As I figured I might get lucky and get one in good working order.
No such luck but at least I have a stock of "parts". They all work, to a degrees. The
Dead crystal issue seems to be common.
Catch you later
G
