In the case of the FTM-400XDR, that meant that Yaesu acknowledged that there were GPS and other issues with the non-X radio and updated the hardware to address issues.
Thanks. I never could find that info.In the case of the FTM-400XDR, that meant that Yaesu acknowledged that there were GPS and other issues with the non-X radio and updated the hardware to address issues.
We've made a lot of progress. There are 31 M17 repeaters worldwide, and with a handheld coming, there will be more.I always suggest to do whatever is available locally in regard to digital. We have Yaesu System Fusion locally on 442.200. I am working on building a D-STAR repeater from an MTR2000 and it will be on 443.575. We don't have a DMR repeater in Columbus and I am not personally interested in putting one on the air, although I have a Motorola DMR repeater sitting in my garage right now. I'm watching the progress of the M17 project, and I am interested in potentially building an M17 repeater in the next couple years if the project continues to make progress.
You're looking at the D in the imprint on the radio body, correct? Look at the label on the bottom of the radio. It will tell you the exact model you received. As already mentioned, different second letters indicate different markets. However, Yaesu doesn't put the region designator on the outside of the radio. This allows them to use the same mold for all models of the radio, no matter what market they are going to.Well, it's here but...... I ordered an FTM-200DR but I got a 200D. What's the difference?
Edit: It looks like this one doesn't have cell phone frequencies blocked. If that's the difference, I don't care.
The First FTM-400 radio (in the US market) was the FTM-400DR. The FTM-400XDR is a subsequent model with a better internal GPS. It was more sensitive and able to lock on the satellites quicker. That's the only difference.What does the X designate, as in 400XDR? I tried to find this some time ago and came up empty.
Awesome! I'll be picking up that CS7000-M17 for sure. Guess I get to start planning my repeater project now. Thanks for sharing this!We've made a lot of progress. There are 31 M17 repeaters worldwide, and with a handheld coming, there will be more.
CS7000-M17
See if you have an M17 repeater nearbyAwesome! I'll be picking up that CS7000-M17 for sure. Guess I get to start planning my repeater project now. Thanks for sharing this!
I've got an MMDVM repeater, but have dedicated it to D-STAR. I don't want to change that because my local users need stability. I'm exploring where I can install a dedicated M17 repeater. Sites are hard to come by around here, but given time I should be able to work something out.See if you have an M17 repeater nearbyIf not - maybe spin one up? Since MMDVM supports M17, it's super easy to do it.
my ftm200 is my goto radio.real easy to program,a first for yaesu excellent recieve .some said skip the 200 but id say they never turned 1 on.only thing when manually going through memorys at end you must go backwards or type 001 and it will go to memory 1Okay, I've done some research (probably not enough; actually, never enough) and I've ordered the Yaesu FTM-200DR. It's coming from Main Trading Co. in Texas. Doing even more research since I placed order, I've decided there's a big learning curve. I'll see how far I get before my brain explodes.
I also ordered the programming software from RT Systems. Actually, I went to the company and picked it up. They're only a few miles north of me. I was impressed when they met me at the door. Then I learned they were testing the volume of the door announcing system. Oh, well. Anyway, I told them what I wanted and, in a few minutes, left with everything I needed. While I was there, Jared even pulled out an FTM-200 and showed me many of it's physical features (SD card slot, removable faceplate, etc.). Mine was one of hundreds of radios on hand to use in their program creations. Everyone was great.
Anyway, the radio is on the way and we'll see how far I get before I scream and make an appointment with a therapist.
(I'm not affiliated with RT Systems. Only a fan.)
get on yaesu site go to my yaesu and register it for warrenty or call yaesu. they are saving paper or they would give full manual and cardThe box is French and English. The label on the radio itself says 200D. There was no warranty card. I bought it from Main Trading Co.
Geeze, Yaesu is still doing that? My FTM-400 rolled over once I hit the end of my memory list. It's like Yaesu's firmware programming has regressed.only thing when manually going through memorys at end you must go backwards or type 001 and it will go to memory 1
Yes.but only flaw i can say. But ive grown used to it.Geeze, Yaesu is still doing that? My FTM-400 rolled over once I hit the end of my memory list. It's like Yaesu's firmware programming has regressed.
