Whistler Trunking Mystery Digit
OpenCarrier
On the WS1040 and its cousins what is THIS number?? It really shows my age when I do ASCII Art: Numbers are examples and the dashes between the info are to keep the system from moving the simulated scanner screen letters back. The Easier to read manual did not show nor did past posts that I could FIND....
WHISTLER
---G
DG---------------771.00000
*ID: -----------------XXXXX
TGL/O ---00098-------Stor
_____________________________
"TSYS" and "00098" will swap with each other during transmission. What does "00098" mean??
ecps92
Taxachusetts
I have the GRE500/600 and if the display info is the same, that would be the Object # that TG is assigned to
In the Whistlers, Object is similar to [way back machine] Channel # assignments
WHISTLER
---G
OpenCarrier
Trunking Channel # is what this is.... Downloaded form the CC. Thanks for the suggestions though.
