I'll jump back in here. The screen shots of the software and radio display do not apply to me at all. I run a PRO-2067, PRO-92, PRO-96, (2) PSR-600 (one base and one mobile) and a PSR-500. None of these have a "System" line on the display. The system or bank is alternatively flashed on the channel ID line and the amount of time between flashes can be selected by the user. I find the flashing back and forth to be quite annoying as I don't know when I'm going to have a chance to look at the scanner display while I'm driving and I need to see the channel ID more than the system or bank ID. When I'm driving long distance I ask my wife to look at the display and the flashing bothers her as well. It is hard for anyone in the passenger seat to read the display as it is oriented to the driver as it is a in dash, DIN mount and that part of the dash ir angled toward the driver.
As a result I program the agency name on each line. I abbreviate as much as I can, but with about 30 full programs covering all of California, Nevada, Arizona and New Mexico, plus a a couple for the southern portions of Utah and Oregon, I can't abbreviate too much as it is easy to forget what MFD means, even when I know which county I'm in. Most of my programs are written for rural areas as I don't usually travel into metro areas by choice. A particular county may have several entities that begin with "M"
The majority of the time I have to add the name of the jurisdiction to every line once I download from the Radio Reference database. This is quite time consuming. I also find some abbreviations written by others to not match my thinking and I change them. Sometimes I wonder if writing a program from scratch is less time consuming than downloading one from the database. For large cities using trunked systems I usually use the database so I don't have to wonder if I've incorrectly entered a frequency or some other system setting that will render the rest of my programming useless.
It is easy to say that putting the agency name on every line is redundant if you have one of the radios that are being discussed here, but if you have the radios I have the redundancy is necessary. The other difference I have with most scanner users is 95%+ of my scanning is in rural counties, like the two county region I live in of about 34,000 people on 13,300 square miles of land.
