Win 97 Glitch
brey1234
Banned
Pennsylvania
Noticed a glitch between my pro 97 and the win 97 programming software---
Sometimes when uploading from the PC to the radio---some of the pl info that's in the pc does not make it to the scanner. Frequencies do---just off and on problems with the pl's
Anyone have a similar problem and/or solution?
scanjunkie
Montgomery County, PA
Hey Bob,
I replied to you on one of the Yahoo group boards. I had the same issue with Win92 once. If I remember correctly it had something to do with the cable I was using, but I can't swear to it. I have never had an issue with Win97. Good luck!!
DonS
Franktown, CO
For channels where you've entered a CTCSS tone frequency in the "CT/DC" column in Win97, but that info doesn't appear to make it to the radio, did you set the "Rx Mode" column to "CT"? If not (i.e. if you left the Rx Mode set to "FM"), the radio will ignore the CTCSS tone freq.
