Win500/310
JohnGingras
SE Wisconsin
Anyway to upload CONV freqs in ascending order you can sort them with the software but will not upload in order.
Thanks, John
al95
Brownsville,Texas
Ok go to conventional tab in win-500 the right click select all then right click again now select sort objects. Right click once more now select reassign objects ID if you get an error message then go to the all objects tab right click then select all then right click once for the last now select reassign objects ID. I hope this helps you
TES
America's High Plains
It tells me one or more object is in use
Your question was about CONV objects. You will get the error you describe if you're trying to assign new object ID's to CONV objects that are the same as object ID's already in use by TSYS objects. If you go to the All Object tab and select everything it's possible to reassign temporary object ID's (like starting at 30000) then follow the procedure described above to renumber the CONV objects. Finally go to the TSYS Objects tab and renumber everything else.
