Windows 7/WIN96
Noblesville, IN Hamilton Co.
Does your web import work fine for trunked systems? I am unable to import any trunked system on my Windows 7 machine. While Win96 is trying to load data into the selection area, it sends the error message "There is an error in XML document (1, 1248)." from the module RRLib::GetTRS_Systems_Full. <OK> Win96 then displays the talkgroups, but no frequencies. When I select the talkgroups to import into my new template, Pro96 stuffs that talkgroup data into the frequencies area of the template, with the data all garbled up. I am on Win96 v01.65. Help, anyone? thanks!
Win96 v01.69 + Windows 7 = Access violation on Trunked web import?
Thanks, PR, I did go find the latest V01.69 version, and that got me a step farther, but unfortunately I'm back to my wits end.
I can web-import conventional systems just fine, but trunked is not working, even with the upgraded Win96 v 01.69. The "Retrieving Trunked System" status window looks like it's progressing normally, but at the end, I see just a brief flash of the results screen and then that results screen closes, leaving the original Win96 intact. I am never given a chance to see the results and select what freq/TG data I want to import in.
At one point an error screen was left in place for me to see "Error: Access Violation at 0x774B9BFA (tried to read from 0x03A38CE8), program terminated" (this glimpse into an actual error message happened only once; I'm not sure how)
I know Windows 7 can be a bit flaky with user permissions but I have validated that I have full rights to all the related Win96 folders, and have had no other problems with the software.
Does this problem look familiar to anyone? What did you do to overcome? I'm googling but results point me right back to this forum. Help!?! - thanks in advance, s.
Update: Access Violation Error a separate problem
After further playing, the Access Violation Error occurs when I try the web import / trunked a 2nd time while the first one is still retrieving the data. It isn't a part of the problem I'm trying to solve, which is the "Retrieving Trunked System" status window progresses normally until completion, flashes the results, then closes before I can select those results.
Note - I deleted all my previous Win96 files and folders, re-downloaded the newest Win96 version from the site, rebooted, and still have the problem.
