Get the scanners ready.. ICE in the forcast. Any new freqs out there I should be getting programmed in for what may come???? I'm sure I'll be at the fire station if the forecast holds true.
Its looking like those up here in Bartlesville will be the hardest hit by this. providing the forecast holds out.
Something that some of you may want to program into your scanners (if you haven't already) is the AEP EDACS system(or your local power company). I've heard some interesting things on this in years past. Also something you may want to monitor is your local gas company. cause I'm sure there will be people complaining about their gas or something.
I'll be listening to everything throughout the weekend. I suspect there will be a good amount of traffic on highway maintenance frequencies, as well as ohp and the sherrifs freqs.
ok i'm using the pro -2006 i would like to hear everyones input on this new trs system if i was too get another scanner what would you guys suggest someone too buy
Edit/Delete Message
