Wireless LAN
BaLa
4GRC+83; Temple, TX 76502
Linkysys WRT54G
Changed Passwords
Running Tomato Firmware
Different SSID (not Default)
MAC Address Filtering
63 Char WPA2 (TKIP/AES Encryption)
I will admit SSID Broadcast is enabled.
Am I safe? :D
bezking
On the Road
No.
AES has a back door, which is why it was approved by NSA but not allowed for classified communications..
Sure about that?
http://www.cnss.gov/Assets/pdf/cnssp_15_fs.pdf said:
The design and strength of all key lengths of the AES algorithm (i.e., 128, 192 and 256) are sufficient to protect classified information up to the SECRET level. TOP SECRET information will require use of either the 192 or 256 key lengths. The implementation of AES in products intended to protect national security systems and/or information must be reviewed and certified by NSA prior to their acquisition and use."
mikepdx
Corbett, OR USA
You could also turn router RF power down to a bare minimum to cover
the area desired if your firmware will allow it.
That's an extra security step.
BaLa
hmmm.
I guess it would be.
With the Tomato Firmware, I actually have it turned up to Max
I take it (the Laptop) and sit outside sometimes so....
Ok I guess it's not quite max...
SignalSeeker
West Sacramento
I would not run over about 150 on power, on other forums I have heard they don't last very long running that high without heatsinks.
I run mine at 72, 150 made no usable difference in signal distance.
Justin
CapStar362
GA, USA!
yeah if you dont hard mod your router with heat sinks you WILL cook your router. i learned this the hard way
BaLa
hmmm..
that wont be too hard
It's not my primary router
I'm using it as an AP only.
For a router I'm using a Netgear WGR614v9.
So If I fry the chip I wouldn't be too upset although I'd like to keep it so, thanks for the tip :D
I also have a WAP54G setup with DD-WRT.
