Wouxon KG-1000G Fan Behavior Question
NYRHKY94
Brunswick County, NC
Question for any other owners of the Wouxon KG-1000G radio. I recently got one and have it set up as a base with a 30amp power supply. All is working fine, however the Fan on the KG-1000G turns on instantly every time the PTT is used to transmit, "even after the radio is just powered up".
Per the manual, it says there are 3 options for setting the Fan. One of them (default setting) says the fan turns on "when the temperature of the radio is high during transmit". That's what mine is set to. That would appear to indicate the fan "would not" turn on immediately after powering the radio on, right? There is another fan setting that turns the fan on "when transmitting". That is how the radio appears to be acting. It's almost as if there is a bug in the radio with the default fan setting.
Looking for confirmation from other owners that their unit operates in a similar fashion...or not. Thanks in advance!
Skypilot007
Medford, NJ
A bug in Chinese firmware, wow that would be a surprise. Does sound that way. I have an AnyJunk radio here with the same fan options and it seems to work as advertised. Hopefully you can report firmware bugs somewhere and the manufacturer may fix it. Good luck.
NYRHKY94
Thanks. Some other owners have reported the same behavior and a request for a firmware fix has been submitted to Buytwowayradios. Their customer service (US Based) is very responsive and everything else about the radio is excellent.
