Wouxon Radio Programming ????
TedWCM
Putnam County
Not sure what forum to use but I need a little help programming the radio. Can I ask for help here or move to another forum ???
ALL help appreciated
TedWCM
Putnam County
Kendrik they are both the same radios and programming and I have the software
I have the New KG-UV2D radio and USB cable and program, started programming the radio first for VHF Freq's. How do you split the programming so that the UHF Freq's show up on the bottom section of display ??
I programmed the VHF list first and it shows up identical on both A/B list ??
The programming software doesn't show how to split freq's ?? or the A/B list
kendrik578
Live Audio Administrator
Greensboro, NC
On the software go to "Usable Function" under "A-Frequency Mode" "B-Frequency Mode" and under option "Channel Disp Way" it gives you 4 display ways. Is this what you are referring to?
kendrik578
Greensboro, NC
Did you expand the box to the left? and it should say "Channel Message", "Usable Function", and "Key Set"
TedWCM
Putnam County
Program
OK my program says Optional function
What I am saying is when i set up my list i have 128 channels listed , but no A Column and B column ??
so both A/B have dupilicate programming I want to program UHF on B channels ?
How do I do that >???
nd5y
Wichita Falls, TX
Both displays show both bands and all 128 channels.
You can't force A to only show one band and B the other.
If you want A to be VHF and B to be UHF you have to dial up a VHF channel in A and a UHF channel in B.
kendrik578
Greensboro, NC
So what your saying is you want JUST UHF on B and VHF on A?
You cant have just UHF on B and VHF on A. All A and B are is just 2 different views basically so you can set on 2 different frequency's at once. Both A and B will always have same programing. In the software you can just set what frequency you want A/B to start at, but it will always be same programing for both A/B.
TedWCM
Putnam County
Thanks nd5y, I guess that makes sense. when setting up UHF how do you setup wide / narrow function ? i have that info for my VHF freqs but not the UHF list ?
kendrik578
Greensboro, NC
If you are in frequency mode you can do MENU>8>MENU to change it.
TedWCM
Putnam County
I understand how to set it up ? but whats the norm setting wide or narrow ? I am Vol Fire fighter and settting radio for mutual response to neighboring counties and dept's
kendrik578
Greensboro, NC
Default is wide. If you have narrow on you will see "N" in top right. Use the default unless you know they are narrow.
TedWCM
Putnam County
Thanks Kendrik SOrry to bother you again, I see my list has some PL's not listed under programming ?do you set it as close to the PL as possible ???
N8IAA
Fortunately, GA
PL's and DPL's are specific to the tone they send. So, settiing it 'as close' won't work. What PL's do you have on your list? Isn't it wonderful that you can get a radio that transmits out of band with no mods, and you can't get all the tones. As my dad always told me: Ya gets whats ya pay for:) Well, not exactly what he said.....
Larry
TedWCM
Putnam County
THanks N8IAA I had some typos in my copied freq list and the were DPL and not PL Got them all straightened out now
TedWCM
Putnam County
I want to Thank Kendrik578 for all his help, THis is one great site for radio info and radio Help and to everyone else who replied. Got my radio up 101% and it's rocking. I was able to hit another departments repeater 14 miles away no problem Great radio so far
Thank you again to all
