WV and their "Private Channels"
In a house along a busy road in Mercer County, Far
Could someone tell me about the Private Channels? Is it just that "Private"? Like just company private? I mean it isn't encrypted private. So, am I correct in saying that if a fire dept has a Private Channel it is just a channel between anyone within that department to talk without anyone else hearing from outside the department?
n5ims
A "Private Channel" is defined by the system owner for that use and may not be any more "private" than any other of their channels, depending on how they set it up. It may simply be a secondary channel that normally doesn't have much traffic and therefore be "private". This channel may be a seperate frequency (on the same band or even on a different band that they may have kept as a backup or for special operations, training, or just because the department would rather let the license expire than give it back to the FCC (you never know when that old low-band VHF frequency will come in handy!).
It may be a simplex channel so it has much less range than their normal repeater channels, so it would be "private". It may be a channel that is only programmed on a select few radios to allow "private" conversations to happen (you've gotta have someplace to plan the Chief's surprise birthday party!). It could even be on one of their normal channels, but use a different PL tone to make it "private". In these cases, a simple scanner can probably pick up this "private channel" if you're within range.
A "Private Channel" could also be a special encrypted channel, or could be code for "call me on my cell", which would make it actually "private" since scanners wouldn't pick them up.
If you're asking about a certain agency's "private channel", you can name the agency and folks may know which of these may apply to them.
Private channels
Well I was really asking about talk groups on the WV State System being private in general. Which can't be of a different frequencies or PL tones. That doesn't exist within a P25 system. But I get your point. A private channel is just another channel that other companies and or people within the same company don't have programed in their radio. Maybe like, let just say that the fire chief(s) of one department may use so called "private channel" to talk with each other about a situation and nobody else in the department would be able to eavesdrop. Ok, that makes total scene to me.
n3obl
Ø
PA
Private in that case might be only that particular dept has the talkgroup in their radios only. So either you need one of their radios or a scanner to hear it.
Frank
