XG-100M Looking for Power connector
N2PDQ
I have a XG100m, and the power connector on the back of the radio is broken off, I think someone used it as a handle with the power cable attached LOL.
Would anyone have a connector, or know the part number where I can order one.
Thanks All
Dirk
redbeard
OH, PA, WV Regional Admin
BEE00.348-3.1
Some part numbers that might help...
  • Harris Connectors.pdf
N2PDQ
Thank you for the PDF. I have seen it before, but it only has the part number for the male power connector, but its a round panel mount.
I'm looking for the OEM, which is a male connector, but has a square mount with the 4 screws.
I could probably use the other connector, but like to keep it factory if possible.
If anyone has a part number, or has any old defective radios in stock, where I could get the connector.
Dirk
Radioman96p71
This is the standard threaded connector, found on the control heads and others. Looking thru the manual, seems the XG100M connector was a custom part ordered from Connxall. Maybe this would fit in the hole?
redbeard
BEE00.348-3.1
Dirk
I too have a Unity mobile so I am aware of what the connector looks like. My assumption was that if Switchcraft made the ConXall cable connector ends, that they probably made panel mount versions as well. Might have to contact them if it was a Harris special order.
