XG-100P P25 I Trunking
Monocle209
I've been hard at work learning and programming conventional and P25 conventional channels. I would like to set up some P25 I Trunked channels to monitor however it seems to be a whole separate beast and there's almost nothing on online about configuring it. Does anyone have a tutorial?
Thanks again.
BMDaug
I am licensed…
Central Colorado, USA
You’ll need to populate your WA Network, Group Set, Trunked Set, and P25 Trunked System properly for the system you want to monitor. You MUST set registration to Never in system settings and uncheck TX in every group you enter. Not following these steps will get you in trouble and get the radio bricked.
You are correct that there is little published information available because making it available is a liability. Using the RR database page and the RPM help menu should get you mostly there…
-B
K2NEC
NA
That's pretty much it. As long as you follow the steps above you should be in business. If your radio displays "CC Scan" or "Band Scan" after all that then double check your settings because something's not right
Monocle209
I know I may be asking a bit too much here, but by chance would anyone have a template/deprecated P25 Trunking personality that I can use as a template to study?
E: I do NOT need encryption here. I'm not even going to look at that until I get way more knowledge.
BMDaug
I am licensed…
Your best bet is to post in your state’s radio discussion forum and ask for help programming for the specific system you are trying to monitor. Be patient and someone may contact you to help or provide a working personality. It’s tough to provide a template because systems can differ quite a bit and all of the settings matter.
Encryption for monitoring? Forget it. Not just in the short term until you learn more, but forever. Municipalities using encryption aren’t going to share their keys with you and you aren’t going to crack AES256. These entities also roll keys from time to time at which point, you’re back at zero if you ever got anywhere to begin with. The only time you would use encryption is if you had a commercial license for dedicated frequencies and wanted to run your fleet of radios encrypted. Then, you would either need keyloading hardware and associated cables, or Harris KeyAdmin, which is quite expensive.
-B
