XG-100P
AF1UD
I recently acquired a XG-100P and was looking to program it and got a quote from my local vendor of $1329.67 for the programming software - RPM/RPM2 with mast dongle and annual updates. For 1 radio that I may not keep for 5 years, that is a lot of money.
I am in the CT area and was wondering if anyone around here had a copy of the software that I could use for an hour or two to program the base unit. A fee can be negotiated for this. Or if anyone has any other options, I'd be open to hear them.
Thanks in Advance!
KevinC
The big K
Super Moderator
1 point
That's a no-no on this board.
I interpret it as he wants to borrow a computer from someone local to program his radio…but I could be wrong.
In the future please don’t play moderator. Report the post (which you did) and let the moderation team handle it.
AF1UD
Correct. I would want to borrow a computer or use someone's local computer to program my radio. I was vague.
BMDaug
I am licensed…
Central Colorado, USA
There is a programming service advertised on the bay… never used it and am not really recommending it… but I’ve seen it.
You could also get everything you want entered into a spreadsheet, organized properly, and then go to your local vendor with that and they can likely program what you need for an hourly rate… If you are trying to unregistered monitor a trunked system, that’s pretty much a no-go for a vender or dealer though.
Also, unless you are familiar with RPM, programming will take some time and you will likely want to revise the programming at least once.
-B
