XL-200 UDC Pinout
crd5014
Hello,
Does anyone have the pin out for the Harris XL-200 UDC connector?
Also, would anyone happen to know if the signal levels for the mic input on the Harris UDC the same as for the mic input on the Motorola XTS-5000 series radio's accessory connector?
Thank you for the help.
Forts
Ontario, Canada
It should be the same as the XG-100P. As far as levels etc, can't help you there I'm afraid.
  • XL-UDC.pdf
mancow
N.E. Kansas
Hmmm I wonder what those resistor values are that select different accessory modes.
Forts
Ontario, Canada
A 6.8K resistor across pins 3 & 5 will identify as a programming cable. A 20K resistor from pin 3 in series to an MX KVL connector will identify as a keyload cable.
