XPR radio
Jacob_I
Elk Grove Village
Just got in some xpr 6000 series radios and when I hook them to my computer and try and read them I am getting an Error #1057. Not sure if anyone has come into this problem with their digital radios but if anyone can help that would be great.
Echo4Thirty
Spring,TX
You can also try using rubbing alcohol on a toothbrush and cleaning the side contacts once you get the proper CPS if you continue to get connection issues.
K2NEC
NA
1057 is a region error not a connection error
Echo4Thirty
Spring,TX
I'm aware of that which is why I said if you continue to have connection errors AFTER he gets proper CPS. I have issues with 6500s not wanting to read and the typical fix is what I listed.
