XPR3300 Codeplug Issue
CChamblee25
I am trying to upgrade an XPR3300 that has firmware 2.05.00 and codeplug 3.00.11. I’ve never seen a codeplug version this old in an XPR3300. I have all of the firmware updates for the 3300 installed on the laptop running CPS. When I try to update the radio using CPS R16, it reports that there are no applicable packages. If I use CPS 2.0, I see two choices to update it. Neither one will push to the radio, due to message “incompatible code plug version”. Can anyone advise on how I can update this radio? CPS R16 is the only one that can read and write to the radio, but it won’t update it, even with all of the updates installed on the laptop.
nhfdcadet
CETsr
New Hartford, Ct
some of the real old firmware require an even older version of CPS to be able to update it, you might need to do it in steps. Try to find someone with an old version of CPS so you don't have to uninstall and reinstall
CChamblee25
To my knowledge R16 and CPS 2 are the only CPS versions available for MotoTrbo radios. I’ll double-check that.
K2NEC
5F6
No, R16 is old, but not as old as that firmware version. Try our R12.1, that might work
CChamblee25
It’s not available on my view Motorola. All they have is 2.0 and R16.
Firebuff880
Boynton Beach, FL
Your right it's not on MOL. You need to take it back to the source you purchased it from and have them update it, or find a dealer near you who will do it for you. Once you are caught up, then use the versions you are licensed for and correspond to the firmware you are using.
