XPR4550 stuck on FlashZap Bootloader Screen
GBLOCK
The Sunshine State
I have a XPR4550 from a lot that is stuck on Flashzap Bootloader screen at power up.
When front or rear OEM USB cable is connected the computer recognizes but unable to read, write or recover in CPS.
Is there a way to user force the flashzap bootloader screen again to attempt a recover? If so which combination of buttons to press during power up?
Any other suggestions to clear this flashzap screen so I can read, write, recover ?
YONGZHICHEN
fUse the flashzap clent software to unlock the radio, back up the tuner parameters, use mototrbo depottool to program and restore. You can also use the flashzap clent software to restore the radio, and finally write the saved tuner parameters.
