XPR5550e Question
Rudy3145
New York
XPR5550e - code plug calls for none PTT ID, yet I still get a tone on key up. MDC ID is set to post. I can't get the radio to key up silent.
Any suggestions?
GTR8000
NY/NJ Database Guy
BEE00
What kind of "tone"? The radio emits a beep when you press PTT? Did you verify if it's actually transmitting an MDC ID?
By the way, how can it be set for both PTT ID Type None and PTT ID Type Post Only? It's one or the other.
Anyway, set the PTT ID Type to Pre Only temporarily and then set the PTT Sidetone to None, then go back to whichever PTT ID Type you actually need. See if that helps.
Your post is confusing tbh.
KG4INW
Midlothian, VA
Are you talking about the Talk Permit Tone, that is on by default (analog and/or digital, conventional and/or trunked)?
