XPR7550e - Assign a button to a DMR Talkgroup
N7AS
Prescott Valley, AZ
One of my channels on my XPR7550e is programmed to do a DMR TG4000 Disconnect.
Is there a way to assign one of the buttons to do that instead?
Reconrider
Inside the Galaxy
Radio Galaxy
Which button? The programmable buttons, or one of the keypad buttons?
I don't think you can make the programmable buttons send that disconnect tg for brandmister, but you should be able to do it on the keyboard buttons(0-9)
N7AS
Prescott Valley, AZ
I was hoping to use one of the programmable buttons.
So, would I just enter 4000 from the keypad and hit PTT? Sounds like a Manual Dial.
alcahuete
Southern California
Entering it from the keypad won't do anything. That will just dial DTMF. You need to have a talkgroup set up for 4000. I just put a channel with the 4000 talkgroup, then key that channel.
N7AS
Prescott Valley, AZ
That's what I do now. I just thought it would make it easier to program a button instead of spinning the channel knob all the way back to the TG4000 Disconnect channel.
Firebuff880
Boynton Beach, FL
You MAY be able to do this by going into General --> Control Buttons, Set up a One Touch Access and then assign that One Touch Access to a button on the radio.. I have never tried this so it may or may not work for you as you would like.
N7AS
Prescott Valley, AZ
I tried that.
I was able to assign a button to a One-Touch Access. but was unable to edit the One Touch Access or add another. I guess I will just turn the channel back to TG4000.
I remember on one of my other DMR radios I could assign a button to a Talkgroup.
