XPR7550E PROGRAMMING
bodnarp
Allendale, Michigan
I entered the EID into my cps 2.0 software. When I went to read my xpr7550e it said I need MOTOTRBO RM Configuration Client for the cps. Where do I get it and is it necessary. Also is there a download site and a cost?
UAT_978
If the radio has been programmed by RM, you cant program it in CPS. You can try opening CPS and doing a recovery, but you will need firmware for that model installed. You can get the firmware from the same Motorola site that you downloaded the CPS. You are HIGHLY advised to read the radio in MotoTRBO tuner before this process and save that file. The recovery process wipes the radio including the tuning values.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
If you do need it, you get it from the same place you got your CPS 2.0 software which is Motorola.
ymichael
EVANSTON
I recently performed a firmware update and made sure to save the file beforehand. However, after testing the new codeplug, the volume won't go above two bars, and there’s no audio output. The radio was working perfectly fine before the update.
N4KVE
PALM BEACH, FLORIDA
I’ve read this before, however over the years I have done a recover for at least half a dozen radios I purchased that were locked. I never saved any tuning file because I didn‘t have the tuner program. I never noticed a loss of performance because the “tuning values were wiped”.
