XPS2500 model 1.5 model numbers don't match
dfb8085
Cumming, Ga
trying to figure out to correct the model number the code plug has for the radio. Been working for a while trying to figure out a way. I have one codeplug with the correct model plug but is written with a older CPS. I can open it with the newer CPS but you guessed it when I go to write it the error of mismatch model numbers shows up. Basically is there a way to get around this? After about a week of trying everything fro draging and dropping and other things but no good has come. Please if anybody can help I would appreciate
clbsquared
Isle of Wight County
Read the radio with the newest version of CPS that you have. Save it. Open up the codeplug that you want to write to the radio in a second window ( you’ll have two screens of CPS. Minimize both instances so they fit side by side on your screen. Drag and drop the codeplug you want to have in the new radio to the screen that has the codeplug you just read from the radio.
It’s called a “top node drag and drop”. It’s in the help menu. There are also some tutorial videos on how to accomplish this.
