XTL 5000 Programming issue, again
LCT123
No problems in the past programming a XTL 5000 until today. All of a sudden CPS Says radio failed to acknowledge, Error context 24, status c0000386. Programming cable is brand new motorola cable. I am running CPS, Astro 25 Mobile R20.01.00. I have uninstalled and reinstalled software and tried different ports. I did notice that the Control head is listed under devices as a Modem. Never noticed that before but it needed a driver installed which I did but it still can read the radio. Any Suggestions?
rescue161
KE4FHH
Hubert, NC
I ran into the same issue with Astro25 portables. I am assuming that MS removed the drivers for that software, maybe because Motorola no longer supports it? So on the most recent Windows update, I lost the ability to program Astro25 radios. I had to completely remove all of the drivers and then do a reinstall of the CPS to fix the issue. I got a warning that drivers were not signed, but I accepted the risk.
com501
Motorola is no longer paying licensing fees to Microsoft so the drivers are no longer included in updates. Great business model, especially for people with PCs that are locked down and can't load new drivers except by IT manager.
rescue161
KE4FHH
Hubert, NC
Yep. We are going through that right now, so there are lots of waivers in the works...
So this must be related to the .NET security updates 6.0.5 & 5.0.17 that showed up today?
LCT123
Frank C. was right in what my problem was even though I don't understand. If I'm not mistaken, the XTL5000 was plugged into com 4 on my computer. A CDM 1250 was plugged into com 6 on same computer. I have never selected "USB" as the port in the past but that seems to work now. I even unplugged the CDM1250 after reading the radio, and plugged the XTL into that com and it still did not work. Thanks for the help!
clbsquared
Isle of Wight County
Don’t confuse physical usb ports with virtual com ports. In most cases when the driver installs, it will select its own com port regardless of what physical port the cable is plugged into. It’s important to go into your device settings and view which com is assigned to that cable.
For instance, my laptop has a total of four USB ports. However, I’m utilizing 15 com ports for all the different programming cables I have. Some are Motorola, some are Kenwood, some are Icom, etc.
