XTL5000 Signal Strength
Scott73
Is there a way to show the signal strength on the display?. If I remember it only shows it when affiliated with a trucked system. Since this radio will be eventually used a receive only using NAS it obviously won’t affiliate. This radio is starting to be a pain to deal with and I might just bite the bullet and get a Uniden scanner which does show the signal level.
KevinC
The big K
Super Moderator
I'm everywhere Focker!
No affiliation, no RSSI. Get a scanner. ;)
N4DES
Retired 0598 Czar ÆS Ø
South FL
Other option is a Unication. It provides a signal strength meter on it as well.
MTS2000des
5B2_BEE00 Czar
A Relm KNG will also do true "RX only" on P25 trunking systems with no stolen software, hacking or system keys: and it's truly disabled from any transmission on said trunking networks. Will display both an RSSI "meter" and true RSSI in -dBM for testng BDAs. Several vendors who install BDAs on the system I care for use them and they work well. Not cheap but GOOD and CHEAP usually don't go together.
K2NEC
NA
Same with most Harris radios
NVAGVUP
Related to MTS2000. Not XTS, but I program my APX for RSSI on conventional. I have a conventional personality set for RX only and I include all of my local RF site channels. (Control and VX) If I select the control channel, I get real time RSSI info for the site. I have a "Cheat sheet" which translates the RSSI values into dBm. This provides real time signal strength as received by portable. (I use this as I evaluate system talkout for testing/evaluating the need for BDA's. (Programming for personality for RX only prevents an illegal carrier event on system [in the event of a radio PTT attempt. Before anyone questions, I am a system admin for system in question)
This feature became available in APX around firmware 17.xx.
