The CPS configuration and operational description referenced in my original post (#14) were pulled from an XTS5000 FPP that works exactly
as it was described. I was curious as to why the "Monitor" button didn't work identically on your XTL5000 and took a few minutes to setup and test this on XTL5000. Sure enough, the mobile doesn’t work the same as the portable even though they are on identical firmware versions.
I found a couple of alternate configurations, one of them comes close mimicking the XTS5000 whereby you can operate the monitor button to facilitate listening to the NOAA broadcasts, but that has a shortcoming in that you can't directly affect a reset following an alert with a press of
the monitor button as you can with with the XTS5000.
This configuration involves changing the Conventional Personality QCII Unmute Type to "OR" while at the same time you option the NOAA frequency(s) populated in the Zone Channel Assignment for PL squelch. Of course, NOAA den’s use PL, but this configuration will keep the receiver muted until a 1050 Hz alert tone is transmitted. The caveat is that you will have to toggle the mode (channel) selector to another
channel and back following an alert to reset the decoder.
I haven't figured out why the auto reset isn't working and will post an update if/when there's new information as I continue to look into
the XTL5000 in this regard. The screen captures below depict the changes described in the above text.
