XTS 1500 Programing Cable
Fire93Medic
New here and not sure if this is the right sport on the forum for this question, but here it goes. I have a Motorola XTS 1500 and the software to program it. I was told can make a programing cable out of an old HT1000 Lapel mic, which I have. I searched online and couldn't find anything specific. I was also told I could find an aftermarket cable cheap enough to not have to mess with the lapel mic. Any onformation on either option would be great.
-Thanks
davidgcet
the XTS does not use a rib box, you can get the real cable in USB or serial and it has a chip in the cable. i've never opened mine up to see what they use, so i don't know if you can build one or not. if you can build one, batlabs.com should have it listed.
mancow
N.E. Kansas
It's possible to make one. I've made an XTS4000 cable which is the same thing with a different end connector. The Astro25 series use busy lines as well as tx rx data lines. The factory cable utilizes a Maxim Max233 chip and a small voltage regulator. Power is drawn from the radio's side connector.
In the end it's cheaper and easier to order a cheap Chines Ebay cable. They are the same design but just miniaturized.
