XTS 2500 NAC Programming
Ghost8546
Bedford, MA
Using the CPS R20.01.00 to program a VHF XTS 2500 what am I missing to be able to enter a NAC ? I would like to set a mixed mode channel, conventional, with PL and a NAC but I can't find the option or location to enter the NAC. What else i would need to check or activate in the personality setting to turn this on. My dropdown is CSQ, PL, DPL am i trying to set this in the wrong place ?
IAmSixNine
Dallas, TX
Its been a long time since i have programmed conventional in an XTS but if you only have CSQ, PL, DPL options your personality is set to Analog only. You need to check the conventional personality and change it to mixed mode. Hopefully someone else can add anything i missed.
chrismol1
P25 TruCking!
NAC would be way over all the way to the right on zone channel assignment page as network ID
prcguy
First you have to make a conventional personality with the RX options checked for mixed mode then TX options checked for Astro. Then in the zone channel assignments point to that personality for the channel you want to be mixed mode RX and Astro TX. Then it will allow selection of NAC.
I usually set up three personalities, one analog only, one mixed mode for the channels I will transmit on in P25, then a RX only mixed mode for receive only of public service stuff. The only change to that is when you have FPP enabled and the radio forces a bunch of channels to have an individual personality, like over 100 of them and for that you have to make a specific personality for most channels.
Ghost8546
Bedford, MA
Thank You ! That was it, a setting wrong in my personalities, and I didn't scroll far enough to the right to see the network ID's open up from this setting.
Thanks everyone for your help.
