XTS 5000 problem will not turn on
mikegilbert
MHz so good
Los Angeles
Wow. You sir are pretty much bottom feeding scum. Item reported.
x2
I wasn't sure how to classify the listing violation, but I managed to send a brief description of the situation to ebay. If you're going to scam fellow ebayers, at least make sure you use a different username. :D
mancow
N.E. Kansas
How do we know he didn't buy more than one at the auction and this is just a working one?
KG4INW
Midlothian, VA
Well then, this wording would indicate he can't use an XTS at all, "The Radio is being sold for parts/non working/repair because I have no battery and no charger to test it with."
How's he using the radio to try to program it then?
mikewazowski
Staff member
Forums Manager
Oot and Aboot
He's never been 100% clear on what he's using.
I asked him to describe his programming setup and all I got back was that he can program an XTS3000 without problems.
Hard to help when he won't answer your questions.
Then again, after seeing his Ebay auction, why bother?
Wrench1
I got the radio to read. It is in inhibited mode. I was able to read the radio with RSS 15.00.00 but if I try and read it Depot 7.0 it says that the code plug is to new. is there any way to get past that?
Astrak
Mesa, AZ
Get a newer version of Depot. Also it might be appropriate to update your eBay listing stating what the problem is with the radio. Obviously by the posts you've made here you have the ability to test the radio.
Wrench1
I have heard that it may be possible to write a new code plug from scratch and load that into the radio?
XTS3000
Seeing as you outright lied on your eBay auction, your not likely to get much further help.
You already have the tools needed to fix that radio. That's all I'm going to say...........
ronenp
If you can get a codeplug wich you can read with the depot then you may program it to the radio .....
MTS2000des
5B2_BEE00 Czar
bigger question is why was it inhibited? could it be the agency didn't intend to surplus such a radio so early and noticed it was missing? since you claim to have bought it from a PD auction, give their radio shop a call. Something tells me they might be missing an XTS5000....
FFPM571
Nashvillle
Or.. He already programmed it for a trunked system and now got it inhibited and is using that story that he bought it from an auction " Like that" to get it uninhibited?
mikewazowski
Staff member
Forums Manager
Oot and Aboot
That was my concern as well.
Innocent until proven guilty however his Ebay stunt proves that he's not the most trustworthy individual.
With that in mind, I'd be cautious offering any further help.
