XTS2500 question
ocguard
PA/MD
In reading Motorola's description of the XTS2500's system config options, it reads as follows:
System Configurations - The customer can select one of the following with the XTS 2500: ASTRO 25 Digital Trunking with Mutual Aid, or ASTRO Analog and Digital Trunking with Mutual Aid, ASTRO Conventional.
Does this imply that the radio can ONLY support one of those options at a time? In other words, is it possible to program into the radio a P25 trunking system, as well as conventional analog channels? I can only imagine that a high-end radio such as this should support all types of systems at once. Can anyone shed some light on this for me?
Also, will the M/A-Com P25ip systems support this radio?
kadetklapp
Indiana
Don't know about the 2500, but my XTS 5000 supports both Analog and Digital systems. Our county dispatches on analog 800 but our city, state police, and others use digital 800. I use one radio for both.
N4DES
Retired 0598 Czar ÆS Ø
South FL
The radio will do analog conventional right out of the box. You have to order the other "digital and/or trunking options" in order to do all or some of the features.
Again it all depends on how it is ordered.
Mr_Observer
You will get analog with the radio but the P25 will be extra as the others have posted. You can however buy just the basic radio now and pay to have it Flash upgraded at a later date. Its a fairly straight forward process that any Motorola shop can do for you in less than 30 min.
You said that you want to put it on a P25 trunking system though and that would be a BIG NO NO unless you have permission from the system operations manager. They can and will send your pricy radio a "remote stun" command that will make it into a several thousand dollar brick. On a P25 trunked radio system it is VERY easy to find and kill illegally programed radios. You will just have to trust me on that one.
MR_O
