xts2500 talkgroups
alexhawkins69
i have an xts2500 and i have everything i need to set up the talk groups for my ASTRO scanner.. question is where do i put the channels? i tried looking around but i wasn’t sure where i put the hex or anything for my channels.
DiGiTaLD
Tslkgroups are defined in trunking personalities or conventional system talk group list depending if you are setting up for conventional or trunked.
Its a hierarchy. First you define a system. For trunking, you then define personalities linked to a trunked system. Zone channel assignment is where you associate a particular selector position to the personality containing the talk group you want on the system you want
Conventional is similar but not identical.
FFPM571
Nashvillle
Its not a scanner... And as I read it, It looks like you want to monitor a trunked radio system. You appear to not have the basic knowledge to program this radio for what you want it to do. You should not attempt it, you can do things to endanger legit users with improper programming
alexhawkins69
Thanks man, I got it all set up!
