Xts3000 800mhz
mustang108
southeast kansas
Radio says there are No system keys installed, but when writing, Radio says can not program due to system
keys installed !!!!!!
cmjonesinc
Do you have a system key matching what you are trying to program loaded in the cps?
cmjonesinc
That's why you're getting that error. Can't program a system without a key. If you're trying to NAS that's another thing but thats a no no subject on this website.
mustang108
southeast kansas
The radio says there are no system keys installed in radio, trying to change
a conventional channel Only, No programming trunk system.
cmjonesinc
Add a new blank trunking system from the menu as the software requires you to have one. Then delete the one in the radio that is causing the programming holdup. The system key is used by the cps and is stored on the computer. It's not in the radio. But in order to edit a system on a radio you have to have a matching system key loaded in the software. It prevents unauthorized users from adding systems or making changes without a key.
Edit:
You can also read your radio, save, and upload your codeplug if you can't figure it out. I can delete it and send it back to you if that is any easier. That cps can be a bit much if you're new to it. Like any radio it's best practice to read and save an original copy before doing any edits. If you do that you can use some trial and error. You won't cause any catastrophic radio failure if you're using normal cps.
n3obl
Ø
PA
Sounds like there is an ASK attached to the radio. Requires tools not available here to clear
