XTL/XTS5000 XTS5000 Channel Announcement is read-only (grayed out)
human8472
I have recorded some WAV files and converted them to the "MFV" format using Astro 25 Portable CPS. I am able to import these files and they show up in the drop-down for Channel Announcement however when I select one it does take. The whole channel Announcement section is grayed out. Here is a screen capture of what I am seeing.
I know I have the feature present on the radio
human8472
I think I found the issue. I needed to go into the Radio Wide configuration and check the Channel Announcement checkbox. Once I did that I was able to set the Channel Announcement. Works quite well especially since I use a shoulder mic and the radio is in a holster.
nhfdcadet
GCT-1
New Hartford, Ct
That’s it, you got it
You’ll find that a lot with Motorola, turning something on in one menu requires something in a totally different menu
