xts5000 error
a417
what did you change? was there a windows update done?
wgbecks
NE Wisconsin
Hi, Ive been programming my XTS5000R without issues all week and now im getting an Error 24 cant read radio. Any help>??
I could be any number of things. However, I've seen a similar problem crop up when programming the radio using USB programming cable
and where there was a brief interruption of the data during a write operation. Try loading (writing) that last known good codeplug to the
radio. If this is successful, then perform a read operation to see if this clears the fault.
wgbecks
NE Wisconsin
Here's a quick communications test to run if indeed you are unable to read or write to your radio from the CPS program.
Connect your programming cable, power on the radio, then open your PC's Device Manager. Look for "Modems". Expand this catagory
to to determine if your radio enumerates. IE: "Motorola XTS 5000 Radio" will appear. If found, select this device and click on the
Modem Tab to reveal the assigned communications port.
Using a communications program such as Tera Term or PuTTY, open a terminal session to the communications port discovered
in the above step. Type "AT&V" without the quotes then tap the Enter key. The radio should return the same approximate text as
is shown below that will confirm if communications with the radio is alive.
Note: There is no echo from the radio, so you'll not see the characters as you type. The default communicaitons parameters
are normally 9600 N-8-1.
CARRIER:9600
PROTOCOL:ALT
COMPRESSION:NONE
FLOW:K3
WV304:192.168.128.1
RADIO:XTS 5000
MODEL:H18KEH9PW7AN
SERIAL:REDACTED
PORT:SIDE CONNECTOR AS USB
SECURE:R050715
CPS:HARDWARE FLOW CONTROL
OK
chrismol1
P25 TruCking!
Thanks, was a dodgy connecter - fixed it.
I've had that error 24 a few times before in my collection of radios. some reprogrammed many times a week/month doing experiments sometimes it just pops an error after many good times and a wipe of the connector and reconnecting the cable it works again, maybe a stuck pin, dirty contact etc
