XTS5000 non affiliate scan MPSCS add more than control & alternate channels?
KD8ZFC
Grand Blanc Mi
Got a motorola XTS 5000 800 MHz P25 scanning the Mich.PSCS using "non affiliate" scan
Was wondering if I can program more than just the control channel frq.'s?
another question is can I add more than two control channels?
example: is I have my county's Control Channels but I also drive into another county which carries/broadcasts my county's dispatch can i also add that county's CC?
Thank you
gjhamilton
Thank you
I assume you are talking about setting it to smart zone. Issue you will have is Radio will roam to another site where the TG you are listening to may or may not be on. On the xts/xtl it’s better to program individual sites an go from there. I haven’t had any luck trying to get smartzone to work using Site Preference either. However it works fairly well on APX
KD8ZFC
Grand Blanc Mi
thanks
that's what i kinda thought about add different county control channels
what about using more than just control channels?
natedawg1604
Colorado
There are several ways to program a system/trunking personality. If you have a large multi-site system you can either (1) tell the trunking personality to ALWAYS monitor 1 site, or (2) give the trunking personality a preferred site, and let it roam to other adjacent sites if the preferred site falls below the specified thresholds. You can also specify a LEAST preferred site. It's impossible to know which option is best for you, without knowing exactly which sites you want to monitor (hopefully you already know that part).
For control channels, you can program however many CC's you want in the main system screen, I believe it's under "700_800_900 ASTRO 25 Control Channels". Just enter whatever CC's you want for the entire system, it can take a large number of CC's (I believe at 100 or more). BTW, PLEASE carefully follow the applicable instructions for NAF scanning, print them out and read them over and over again, to make absolutely certain you know what you're doing...
W
W4ZMJ
Guest
You could always set the scan up for a multi system I've used that before when setting up a scan list it seems to work okay but there's a little lag sometimes in the Transmissions
Sent from my LG-H343 using Tapatalk
KD8ZFC
Grand Blanc Mi
Yes I definitely know what I’m doing I’ve done weeks and weeks of research before even attempting to program for NAF I’ve already have it programmed and working great!
Was just curious about the question I had
Thanks again for the info.!
