XTS5000 P25 RX MODULATION
leyendaoculta
Caguas, PR
I have my Motorola XTS5000 i try to heard non encryption communications and i found in the cps a field grayed out. And my radio has this flashcode 58908A-901E87-4 i
if i need to reflash my radio send me the flashcode with this option ready to use
chrismol1
P25 TruCking!
Right click on for help file. If you saw the help file it would state
Rx Modulation (Trunking System, Advanced)
Selects the receive modulation type for the current Trunking System. This field is for use in trunked systems that allow Two Level Secure Receive or Four-level Recovery for Extended Distance (FRED) operation. This field affects SECURENET voice only. Rx Modulation should be set based on the expected secure voice receive format for the trunked system.
This field allows the user to configure the radio's system for strictly binary (2 Level) secure receive
Only accessed: When the Secure Configuration Secure Equipped field is enabled.
N4KVL
ÆS 8675309
South FL
The trunking system your are currently editing is Astro25. SECURENET is utilized on Type II trunking systems.
There are no Type II systems in PR that this setting is necessary for.
merlin
DN32su
You are certainly doing it all wrong. Do a LOT of reading about NAS scanning before you even power this radio up with an antenna.
Blinky red light = radio is trying to affiliate with the system. "BAD, VERY BAD"
MatRat80109
Colorado
"BAD, VERY BAD" Describes this well. The System Admins will eventually see your radio since it generates an error in the log files every time it fails to affiliate.
Best case is the Admins "stun" your radio, turning it into a paperweight/door stop. Worse case is a FCC agent, with local law enforcement, tracks your radio down and shows up at your door with a fine book and shiny silver bracelets in their back pocket. It really depends on the problems caused and the moods of those involved.
MR
MTS2000des
5B2_BEE00 Czar
Ohhhh ....David, i LOVED his instructional videos.
/s
So did I. In fact, I used them in a presentation I gave to fellow area system managers about how to identify possible infiltrators into our systems.
Amazing he would confess to such crimes and knowledge on video like that, but shows you how brazen some folks are. FAFO to the max.
a417
I imagine it went something like this - "The prosecution would like to show you an exhibit marked as Item 1. It's a video in which the defendant does all of the prosecution work for us, and then we will rest our case."
ElroyJetson
As time goes on I'm getting progressively happier with Harris radios. They give you actually "safe" options to scan without affiliation and not too many tricks needed to do it.
Why Motorola has never quite figured out that enabling a true RX only mode would actually be beneficial for them and their customers is beyond my capacity to understand.
A certain percentage of people are going to do it anyway. Might as well make it easy for them to listen with no chance of affiliation which most of them would prefer to do if at all possible.
But we're talking about a company that still doesn't seem to understand that their Advanced System Key also ensures that many surplus radios make it to the used radio market while still active on their original system, and with no "legitimate" aftermarket means of deprogramming them. Which is a huge security hole.
If they were really smart, the CPS would always have the ability to delete trunking data without a system key. Key required to retain or add data. That's how it SHOULD be.
