I see you have the antenna pointed up at an angle, is it pointed right at what you want to receive or is the satellite straight above you? The X-wing project posted here on RR has a null straight in line with the support tube and the main lobe when the tube is pointing straight up is roughly from 20 to 60 degrees off the horizon. This was chosen for best reception within the continental US when the antenna is flat on the ground and the support tube is pointing straight up and the main lobe is otherwise omni directional. The only time you might need to tilt it over is if your on the equator and the satellite is directly above you.
This is all due to the unusual 1/2 wavelength spacing of the elements off the ground plane to get the desired radiation pattern. Other commercial/military X-wing antennas have the elements about 1/4 wavelength off the ground plane and must be pointed at the satellite.
