Check the link I posted. They've got a picture of the actual Yaesu tuning procedure.
Dave
I can't seem to find the transmitter tuning steps!
Gerald
Thanks Dave
I have all 50 steps
Gerald
Tomorrow Thanksgiving at our house.
Hi Dave,
I followed your steps for tuning. Everything fine until step 28. Idle current
should be 60 ma. I get no movement at all on the meter!!
Doesn't look good
Gerald
Dave,
I do not have the original mic , using a Cobra radio mic. I am also still on the dummy load????
Gerald
Dave,
No movement at all
Common problems with FT101s <snip> 2 Missing jumper. There is a jumper required on the main accessory plug in the back. If it is missing, the filaments in the finals and the driver tube do not work. You will not have any cathode current to measure. Look through the vent holes and see if the filaments are lit. <snip> I have one question, does the radio receive? The preselector tuning works best peaking a received signal. <snip> Craig
Common problems with FT101s of a certain age (i.e. they are old!):
1 Intermittent switches. They may need a cleaning. In the day, carbon tetrachloride which is bad for you spray on tuner cleaner, Rock them back and forth, main problem is the band switch.
3 As mentioned before, flat capacitors. This usually causes other problems, not failure of the finals.
I have one question, does the radio receive? The preselector tuning works best peaking a received signal. The 10 mhz receive only band would test the sensitivity of the receiver. WWV should be receivable at your location.
Craig
