When the Yaesu FT227R transceiver is turned on, the display shows 7.000, which I guess is 147.000 MHz. Mostly, turning the tuning knob causes the frequency display to increase, whether the knob is turned clockwise or anticlockwise. I read a relevant post on this forum by techman210 on 8 January 2020: "If you can change frequencies in one direction only, then there is an optical coupler attached to the backside VFO wheel. That is either bad or just dirty." The manual says the two photo-interrupters are PS-4001. I can see them like disk brakes, on each side of the disk on the knob axis. I blew the area out with compressed air, with no improvement. I would be grateful for advice about this. Is replacing the PS-4001s likely to fix the problem? Is procuring and replacing them in the radio straightforward? I'm moderately handy but not a professional electronics repair person, by a long shot.
Is running a 13.8v radio at 12v a bad thing?
