Yaesu GMRS?
AB4BF
EM93cs
Thanks. Would you consider then, the Wouxun brand to probably be the best overall quality choices available?
I have a Wouxun KG-935G GMRS HT and I love it. Our repeater is approximately 13 miles away and I hit it sitting at my ham shack with no problem. I found an old Rat Shack gmrs HT that I gave to my grandson, and I have no problem talking simplex to him on any of the simplex frequencies. Plus it has great audio! You can't go wrong with Wouxun.
73, WRTA416
Absolutey not.
Wouxun and Quality are not two words I'd use in the same sentence.
Wouxun are low end, bottom of the barrel Chinese radios. In fact, you cannot do much worse. They are "radio on a chip" and have poor filtering and very poor quality control. Yes, they'll work in some applications, but you can -easily- do better. If you are looking for the cheap solution to get on the air easily and with the least amount of cash, then they may be a good solution. Other than that, there are absolutely better options.
Give us an idea of exactly what you are looking for, and we can make some recommendations.
jeepsandradios
East of the Mississippi
Wouxun is just a higher priced Baofeng. Built same way. Ham radio with modified software for GMRS only. As MTS said Kenwood makes a good little radio. Guess it really dependso n your "need" of a gmrs handheld
AB4BF
EM93cs
Wouxun KG-935G, GMRS Handy-Talky, FCC Type 95E accepted for GMRS only. Published in the Operations manual and also in the type 15 acceptance tests.
Couldn't readily find it for the Kenwood...
AB4BF
EM93cs
Thanks AB4BF. Good info. Would there be much performance difference in the SOC 935G and the Superheterodyne UV9G in your opinion?
I don't know exactly, and I'm not sure about the superhet being in the UV9G, but the sensitivity is excellent on my KG-935G. Its currently 149.95 at buy two way radios dot com.
jaspence
Michigan
Superhet receivers are a different league from from the CCR method of handling receive. I have both types on DMR, and the superhet audio is far superior in quality and clarity than the cheaper radios.
Project25_MASTR
Millennial Graying OBT Guy
Texas
Buy Two Way Radios offers a Wouxun model that is a superhet design but still, Wouxun is still a low cost product that can't stand against the stuff Kenwood was manufacturing for LMR purposes.
WRVG635
Hot Springs, Ar
I’m just looking for a GMRS radio for casual conversations and scanning of weather stations and other municipal and state channels. Not really interested in ham or serious usage.
Rt169Radio
CT
I haven't heard of municipal or state agencies using GMRS so that would be a new too me, but anywho here are some GMRS radios that you might be interested in.
sallen07
Rochester, NY
Am I confused GMRS=UHF. WEATHER=VHF
not the same bands.
Many GMRS radios will receive VHF and UHF; they are just locked to transmit on the GMRS frequencies. Several have the NOAA frequencies pre-programmed and may even do weather alerts. A lot of them are marketed as "scanners" although I'm sure a real scanner is a better alternative. I have to chuckle at some of the marketing, where you get "for free (a $50 value)" 900 "emergency services" frequencies so you're ready just in case. Of course these are all analog-only radios, so the chances of the local emergency services frequencies being in the list are slim (and getting slimmer) and even if they ARE, you've got 890 other channels to scan!
Personally I find it a bit of a stretch to call Wouxon radios "CCRs". Yes, they are made in China, although many are superheterodyne, not SOC like a Baofeng. But I also don't consider $100 - $250 "cheap". Maybe they are ECRs? :)
I have no idea how good the filtering is on their superhet radios; it may be poor or non-existent. But they aren't SOC.
jtderby
Sparta, NJ
The Kenwood is a superior radio and you can probably find one close to the $149 that you can buy the KG-935G at. That being said, then you have to either get someone to program it or invest in whatever is needed to program it yourself. And, as noted above, it will not receive weather channels as they are on the VHF band and the GMRS channels are on the UHF band. If you're looking for more of a turnkey solution, I'd recommend the Wouxon even if the quality of the radio isn't as good as the Kenwood.
gman4661
I was given a Kenwood TK-350C in near mint condition. The battery is dated 1997, so it's an older radio. I would need to purchase a battery and charger. Don't know if it's Part 95 accepted. Any thoughts regarding this particular radio for GMRS use?
