Evening all,
Long time lurker from San Antonio, first time poster here. I've read just about every thread and have still missed something on this scanner.
Left scanning back in the early 90s and recently had an impulse to start again w/ the Pro-2096. Found all my other old scanners, put up another antenna, the whole deal. This hobby has sure changed!
After subscribing to RR.com, I learned right away (mistakenly?) that scanning SAPD is not going to work. I've tried everything and its either total silence or just data stream junk.
So, I started loading the small town PD, and fire stuff. Not getting much for my buck here either.
I've got this scanner sitting beside a PRO-2006, a 2066, 43, 83, 90 (there's an old uniden mobile around here somewhere as well).
The 2096 will receive the aircraft and VHF bands when I use the Attenuation function. But when I use it, I end up losing the more distant signals that are still clear on the other scanners.
If anyone from S.A. is reading, I'm on the N.W side and can receive from Hondo to Spring Branch to Kirby, just not on the 2096.
Is there something I'm missing or could this particular unit possibly be defective?
TIA for any advice.
rickbnsa
TIA for any advice.
rickbnsa
