For the most part, I don't see any problems with the programming of the trunked systems. Check your squelch setting. It should be 2. I would try the filters on the sites you are using. Wide invert often works well. I see that you have ID Search turned on for the York County and Palmetto 800 trunked systems. You should be receiving everything on the sites. In ID Scan, you will receive only the talkgroups programmed. For now, turn on all of the Service Types in the Profile Editor. Under Scan Selection, make sure that Download and Monitor are both turned on for the favorites list. Download sends the favorites list to the scanner. Monitor enables it to scan. You can check it in the scanner. Press MENU. Set Scan Selection will be showing. Press E. Scroll to Select Lists to Monitor. Press E. You should see the South Carolina favorites list in the display. If it is off, scroll to it and press E to turn it on. Press AVOID to exit the menus.
