I'm currently having an issue with two older 4010 consoles, where it takes a fairly loud RX audio signal to unmute the console speakers. It's causing lower volume radio traffic to never unmute and traffic to be missed. This is on a simple 2-wire tone-remote system. The local radio shop has attempted to correct the issue by cranking the 2-wire RX audio level way up into compression, however the issue persists. It's like there is a threshold to keep the speakers from unmutimg on any kind of line noise, and the threshold is set far too high.
Looking through the service manual, there is almost no mention of such a feature/setting. The only thing mentioned is a Channel VOX hang time, used to control patch TX timing and the call LED. This hang time is software adjustible, however there is no mention of how to adjust any actual VOX threshold.
Anybody ever came across this problem or have a fix?
