I noticed the thread on switching NFM to FM for a P25 Trunked System you monitor. So I went ahead and ran 1/2 hour on both settings, recorded and then compared them. I'll do more and it's early but I'm pretty sure the FM setting works better. It seems less likely to drop the beginning of transmission. I did this on MPSCS (Michigan) for Van Buren County.
The next thing I'd like to start trying to improve is the following:
As an example, a voice transmission starts and the dispatcher will pause for a moment (voice goes silent) and then starts talking again. A lot of times the BCD436hp will miss anywhere from the beginning of the first word to as much as 3 words. I noticed this also happens on conventional frequencies as well (Non P25 systems).
What settings on the scanner should I start fiddling with to help improve this? What settings for P25 and what settings would I mess within the conventional channels settings.
It's very similar to VOX (I have no idea if the scanner acts this way) but it's going silent and then it waits for a trigger of the human voice but it's a bit late opening the "switch" that lets that voice come through.
Thanks for any help.
