secretspy711
Trying to decide on the best antenna and mounting location for my situation and looking for advice.
I have a Jeep Wrangler JKU, hard top with a Maximus-3 roof-rack. (It's not the typical roof rack you see on jeeps that have bars extending down to the tub on each corner of the jeep -- this one is a platform that sits on brackets that penetrate the hard top and is supported structurally by the roll bar inside.) Eventually I will mount 2 of whatever antenna I choose... 1 for voice and 1 for APRS.
Also of significance is that I'm in Colorado, and there are repeaters on mountain-tops, so a long antenna may not be necessary.
The best location for RF-performance would obviously be right in the middle of the roof rack. (I may need to improve the grounding of the rack itself for this to work.) The problem is that I also like to park in a garage and there's only about 4-5 inches between the roof rack and the garage opening. And if I'm mounting 2 of them, they would probably end up on opposite corners, or 1 on each front corner.
I don't *think* I want a manual foldover antenna, mainly because I've been using my radio around town, and I don't want to have to get out of the jeep to fold the antenna down every time I come home. But maybe after the novelty wears off then I might find myself only using it for trail runs and not for "everyday" use... I don't know. It's not looking that way though.
Option 1 is the Diamond K9000 motorized mount. Neat, but a little pricey @ $100.
Option 2 is to get a somewhat short, but rugged & flexible antenna and just let it smack into things. On my list are:
Comet SS-460SB
Comet SSB-1
Diamond AZ504SP
Larsen NMO-2/70SH
All of those antennas are between 15 and 19 inches tall, and are flexible or include a spring near the base. These will smack the garage but won't be so tall that it would be a nuisance.
Option 3 is to get a taller antenna like a Larsen NMO-2/70B (34.75" tall) and mount it on the cowl / fender. I'm pretty sure I can mount it there and still fit in the garage. It would be similar to my AM/FM antenna, except mounted on the driver's side. My worry here is that the metal A-pillar and roof-rack will block much of the radiation pattern. Is a longer antenna mounted lower better than a shorter antenna mounted higher?
Comet SS-460SB
Comet SSB-1
Diamond AZ504SP
Larsen NMO-2/70SH
