PSR-310 Antenna Upgrades (portable)
ryradio
I was wondering what success any 310 owners have had with antenna upgrades.... the 800mhz antenna upgrade is not needed for me.
gmclam
Fair Oaks, CA
Antenna
The antenna that comes with the scanner is a great compromise with its ability to receive from 25-1300 MHz. If you only want a portion of the spectrum, then I guess you could "upgrade" to an antenna designed for those frequencies.
I run the RS800 portable antenna if only monitoring UHF, otherwise use the stock antenna. However, when at home I connect to my discone or other external antennas. When mobile I have a VHF/UHF mag mount.
It all depends on what you want to monitor.
eagleswings01
Although I haven't made the purchase yet, many 310 owners seem to love this RS antenna. The price is very reasonable and it gets pretty good reviews. I should be adding it to my scanner next month.
Good luck!
